Car not accelerating properly and clicking/ticking from front end
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
RNF919
car not accelerating normally. ticking noise front end, noise goes away when foot off the gas.
Oct 31, 2019 at 3:44 AM
The thing that makes the most sense would be a CV axle.
Here is a guide that talks about this in more detail:
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/replace-cv-axle
However, the fact that it stops when you let off the accelerator points to a drive line issue. I would suggest lifting the vehicle and putting the drive wheels on jack stands and then letting them spin in gear and seeing if you can find the clicking noise while laying underneath.
Nov 1, 2019 at 9:27 AM
