clicking nose from drive shaft when I accelerate
19,500 MILES • 3.0L • V6 • AWD • AUTOMATIC
TOPGUN50
When I accelerate from a stop light I can hear a clicking nose from the drive shaft, but when I'm on the highway the nose goes away even at low speed the I don't hear the clicking nose.
Can it be the flex disc or the center bearing needs to be replaced
Feb 9, 2015 at 12:24 PM
DR LOOT
  • 2,311 POSTS
it sounds like it could be a CV joint in one of the axles
Feb 9, 2015 at 1:01 PM
TOPGUN50
I had the front and rear wheel excel changed at 15000 miles the was sitting in a my friend's garage for 3 years it was sent to from across seas ,I was just wondering if Ac hose that is located near the flex disc was dripping down on the disc prematuraly damaging the disc.
Feb 9, 2015 at 1:14 PM
DR LOOT
  • 2,311 POSTS
most likely when the vehicle is shipped across the sea the discs may have developed a coating of rust which is probably causing the brake pads to grab may be causing the clicking noise how far have you driven it since you've taken it out of storage?
Feb 9, 2015 at 11:31 PM
