Clicking noise while turning With acceleration
52,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DHAVAL1506
I am having clicking noise while turning right with acceleration.
It doesn't come if I turn normally without acceleration.
I changed drive shaft before two days. I don't know it's is steering noises with particular angel or not.
Apr 30, 2020 at 9:09 AM
  • 110,248 POSTS
You mentioned you replaced the axle. Did you replace both sides with new joints? A clicking when turning is usually the result of a bad CV joint. Take a look through these two links:
https://www.2carpros.com/articles/how-a-cv-joint-works
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Let me know if the second one mirrors what you are experiencing.
Take care
May 1, 2020 at 3:09 AM
