clicking noise under hood when car off
171,860 MILES • 2.0L • 2WD • AUTOMATIC
LADYK3708
When I cut the car off after driving it's a clicking noise under my hood near the throttle body
Mar 22, 2014 at 11:15 PM
HMAC300
  • 48,601 POSTS
it might be the iac motor have it checked locally
Mar 24, 2014 at 12:16 AM
LADYK3708
I had a code for my computer goin bad or possible shortage or electrical. .. Others have said possibly electrical problem
Mar 24, 2014 at 5:57 AM
HMAC300
  • 48,601 POSTS
if they are saying your computer bad then check battery for condition including load test first. autoparts do for free. If there is a code you should have told us or at least given the code so we can do a better job. but it could be either
Mar 24, 2014 at 6:02 AM
LADYK3708
The code given was po601 and I had first got a code for under voltage so I put a new battery in and then a new light switch because my fog lights would not work.. then the clicking noise started after all this..
Mar 24, 2014 at 8:00 AM
HMAC300
  • 48,601 POSTS
check this as it may be what this tip is saying like a cracked spark plug they will sound like a click. also have the charging system checked it may be low on voltage. it could also be the fan belt and tensioner . Other than that I have no further suggestions.
Mar 24, 2014 at 8:07 AM
