Clicking noise in the dashboard
2009 CHEVROLET IMPALA
78,000 MILES
LUVPACKGW
The last time this happened it had to do with some type of relay. What is the approximate cost to have one of these replaced? I believe that in some cases they may have to dismantle the dashboard.
Aug 29, 2018 at 11:59 AM
  • 110,190 POSTS
The relays for the vehicle are located under the hood. I attached a picture of it for you to see. If you are getting a clicking under the dash, chances are it is a blend air or mode door actuator. Take a look at this link and focus on the "What Goes Wrong" section and let me know if that is what you are experiencing.
As far as a relay price, it is a ten minute job and the part should be under $20.00. The aforementioned actuator requires more time and is located under the dash.
Aug 30, 2018 at 6:14 PM
