Clicking noise
TOBIE_ANN
When I go to start up my truck it made a clicking noise in the (facing the engine) top left corner and will not start. I am thinking it might be the starter but I'm not too sure. I get multiple clicks when I try to turn the engine on.
May 28, 2013 at 1:19 PM
HMAC300
  • 48,601 POSTS
check battery for condition and load test first. then check to see if starter gets same voltage as battery it shold have 12.4volts minimum static. then have an assistatnt try tostart turck and while he is doing that you hit body of starter with hammer. if it starts replace starter
May 28, 2013 at 11:41 PM
TOBIE_ANN
Ok we'll I replaced the starter today and it is still making the clicking noise
May 29, 2013 at 8:24 AM
HMAC300
  • 48,601 POSTS
youi'll have to have a pro look at this then so he canactually hear the sound. it cold be aproblem where starter mates to engine and flywheel is worn casuing it.
May 29, 2013 at 11:12 PM
