Clicking noise after replacing fuel pump
74,047 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JOEGREEN63
I just changed fuel pump. Hooked up battery now I have a clicking noise from dash with out the key in the ignition. Turn key and car will not turn over or do nothing.
Apr 25, 2019 at 5:10 AM
Good afternoon,
This sounds like low voltage from a low battery.
I would charge the battery until you have 12.6 volts and then try it again.
Apr 25, 2019 at 6:28 AM
