Once my ignition clicks off there is a clicking noise?
200,000 MILES
1969ANDY
  • 7 POSTS
Once my ignition clicks off, I get a clicking noise from dash and needles move slightly. i have just had a starter and ignition barrel replaced, it wasn't doing it before. Any advice would be appreciated.
Sep 21, 2022 at 8:05 PM
  • 55,709 POSTS
Thanks for the video, it helps. This sounds like the battery is no good. To be sure let's turn the headlights on for 5 minutes and see if they stay bright. This guide can help us, and I have included a generic guide on how to change the battery out correctly:
and
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Please go over these guides and report back.
Sep 22, 2022 at 3:13 AM
1969ANDY
  • 7 POSTS
Thanks for your reply, I'll give it a try.
Sep 22, 2022 at 4:50 AM
  • 55,709 POSTS
Please let me know what happens.
Sep 23, 2022 at 4:47 AM
1969ANDY
  • 7 POSTS
I tried the battery this evening and it's okay.
Sep 23, 2022 at 4:54 AM
  • 55,709 POSTS
Are the battery cables clean and tight?
This guide can help:
Please go over this guide and report back.
Sep 24, 2022 at 3:07 AM
1969ANDY
  • 7 POSTS
I put it on the machine I've got, it wasn't showing any faults and cables are tight and clean on battery, if I sit in the van, lock then unlock it stops, but then it locks the doors it's self after a couple of minutes.
Sep 25, 2022 at 7:39 PM
  • 55,709 POSTS
It sounds like the BCM is going out or the instrument cluster itself. Has this car had any water damage? When they did the code read did, they do a CAN scan?
This is easy to do, and it goes over all of the systems in the car. Check out this guide:
Sep 26, 2022 at 10:23 AM
