I get the A/C kicking in, this is slightly different, loud click five or so times from transmission area. truck was cold, it stopped.
Jul 31, 2017 at 6:42 AM
✓Experienced Mechanic
It sounds like you have a throw out bearing that is going bad, here is a guide that will show you what you are in for when changing the bearing. I would just do a clutch at the same time.
