Clicking noise while turning
96,000 MILES • 1.6L • 4 CYL • 4WD • MANUAL
DAVAX
When turning slightly the steering wheel (not full turn) to the right I hear a clicking noise. It is heard only when going round bends on gear. When turning in neutral the sound is not heard. I though it was the outer CV joint so I changed it. The sound is still there. Could it be the inner CV joint? If not what could the fault be? Thanks for your help.
Jan 19, 2019 at 4:15 AM
Good afternoon,
It does sound like an axle shaft. I would replace the entire shaft. They are very inexpensive.
https://www.2carpros.com/articles/replace-cv-axle
What side has the issue? did you check both sides?
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Roy.
Jan 19, 2019 at 5:35 AM
DAVAX
Thanks for your prompt reply. It is only heard when turning to the right. No clicking noise when turning to the left.
Jan 19, 2019 at 10:43 AM
Can you tell which side?
Jan 19, 2019 at 12:33 PM
DAVAX
Right side.
Jan 19, 2019 at 2:30 PM
I would remove the axle and look at both CV joints. If none is found, then replace the axle shaft.
Jan 19, 2019 at 9:15 PM
DAVAX
Okay. Thanks for your interest and help. I will check the shaft.
Jan 20, 2019 at 1:37 AM
You are welcome.
Always glad to help.
Jan 20, 2019 at 1:42 AM
