Click sound when clutch is engaged
35,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SAHAND KESHAVARZ
i hear a clicking noise when i press the gas pedal, only when I engage the clutch not when shifting gears. the car is a dual clutch transmission and it only happens when i let go of the gas pedal then press the gas pedal again while the car is moving.
Oct 9, 2019 at 2:00 PM
Good morning,
I would have someone check the engine mounts to be sure the engine is staying stable and not moving.
The engine may be moving up and down during loading and unloading when the torque is applied or taken away.
Oct 9, 2019 at 6:46 PM
