Click noise
17,000 MILES • 6 CYL • AUTOMATIC
MZCOLLINS2017
Hello, when I tried to crank it, it has a click noise when trying to start the car.
Feb 27, 2018 at 4:45 PM
  • 31,937 POSTS
sounds as if the starter is faulty or you have poor voltage to the main starter connection. the click will probably be the starter solenoid engaging, this is also the main starter internal switch. if the contacts are burnt or you have low voltage or a bad ground the starter will fail to turn. check power and grounds and if both are okay get the starter checked out.
Feb 27, 2018 at 5:41 PM
