Click but no turn over?
161,078 MILES
JROC1298
New battery, starter tested good two different stores, power to big bolt no power to small connector when key turn to run position.
Nov 7, 2022 at 11:13 PM
  • 55,732 POSTS
Thank you for letting us know what you have tests it helps, here is the wiring diagram for the starter and it looks like there is a relay that needs to be tested or swapped out.
Here is the location of the relay and a guide to help test it:
Also try the starter when the car is in neutral, this will rule out the gear range sensor. Check out the images (below). Please let us know what happens.
Nov 8, 2022 at 12:58 AM
JROC1298
Hey, thanks for the response. It was ground wire off. Now it crank but won't start, check to see if it's fuel it was I think it's the spark.
Nov 9, 2022 at 12:54 PM
  • 55,732 POSTS
Glad we got one part fixed. For the new issue please post your new question here, you must be logged in.
Cheers, Ken
Nov 11, 2022 at 5:53 AM
