no engine starter operation?
100,000 MILES • 4.2L • 6 CYL • 2WD
JOHN CARMICHAEL
Turn the key to crank clicks one time and there's no start. I have cleaned all the top side connections. I can crank it by jumping the solenoid with a screwdriver.
Mar 6, 2020 at 9:28 AM
  • 110,251 POSTS
If you can jump the solenoid and it starts, then there is a connection issue. Is the smaller wire on the starter clean and tight?
I need you to check something. Have a helper turn the key to the start position while you check for 12v at the smaller wire on the starter. Here is a link that explains how it is done:
I noted that you cleaned all connections on top. Have you done anything at the starter itself? Also, have you tried to see if it starts if it is in neutral?
I attached three pics below that are the entire starting system schematic. I overlapped them so you can follow them. Make sure to check the fuses indicated in the pics as well as the relay.
Here are a few links to help when checking:
and
and
Mar 6, 2020 at 1:35 PM
TURNERDJ
Engine does not crank replaced battery checked fuses tried charger and jumping all lights and excessarys work wheat's next
Oct 28, 2020 at 6:14 AM (Merged)
JDL
  • 16,098 POSTS
If no security lamp on the dash lite when you try to start, if starter motor won't crank, have to check circuits at starter motor. Be sure battery has a full charge and battery connections, good.
To check fuses, you check the fuse isn't blown, also check for voltage on the fuse circuit. The purple wire at the starter, should be hot with key in the crank position and starter relay energized. Any starter testing on the vehicle, make sure tranny is in park or neutral and the parking brake is set. The red wire at starter is battery voltage, hot all the time.
JDL
  • 16,098 POSTS
Just to add, the engine isn't seized?
GWHIZZZ2CP
didn't start last Thursday...I jumped it with at jump box and it finally started.
Put in a new Battery last Saturday...as the one that WAS in it was at least 4.5 years old, since I have had the vehicle that long.
There is no even trying to start...it is dead quiet...voltage when running is normally around 14v...
The security lock light stays on when trying to start...which I think is normal??? but I am guessing that since it doesn't start it says on.
Any suggestions???
It is also saying something about brake system service now - didn't notice that last week.
FIXITMR
  • 9,989 POSTS
sounds like cable connection issue. check both ends of cables.
  • 75,988 POSTS
You might want to have the antitheft system checked-start here
GWHIZZZ2CP
Thank You...have been looking towards the anti-theft and reading about bypass modules..trying the 10 minute leave the key on...then try to start it trick to see if we can get her started.
RKANIA
Over the past week, when I turn the key in the ignition, it doesn't turn over. On the second or third attempt, it starts fine. Could this be a battery or starter problem or something else?
SERVICE WRITER
  • 9,123 POSTS
There is a tsb on the battery cable terminal bolt also this guide can help us fix it
JGOODWIN1980
My 2004 envoy wont start. We just changed out the starter and the battery is new also. The alternator tests good. Sometimes the security light flashes and and the alarm will go off for no reason. The car will start sometimes and not sometimes. What would make that happen?
  • 75,988 POSTS
Start by having the AntiTheft/Security System device checked out-
JGOODWIN1980
IS THERE A WAY TO BYPASS THE ANTI THEFT SYSTEM?
RIVERMIKERAT
  • 6,106 POSTS
The Theft Deterrent System on the Envoy will communicate any errors or problems with the computer control system. Hook up a scan tool and run it through a theft deterrent system diagnostic.
Yes, the theft deterrent system can be bypassed, but not easily.
CADIEMAN
  • 3,544 POSTS
the security lite flashs when u open the drivers door.then when you lock the door it stays on.then shut the door the light will go off after 40seconds.the alarm is set then.
52CASTER
The problem is that when the key is turned on sometimes not everything is powering up like it should.Sometimes when the key is turned on,the tach and speedo along with other indicator lights go crazy,that's when it will not crank. But I can turn the key off and on 3-5 times and eventually get everthing powered up like it should,then it will start ok. I thought I had a bad battery,replaced it,same problem,now I'm thinking maybe a relay?Any one got Idea's?
BMRFIXIT
  • 19,053 POSTS
do you have a security light on
and if so turn key on and leave it on for 10 to 15 min
charge battery and check charging system
have the BCM checked (data and codes )
BMRFIXIT
  • 19,053 POSTS
checking the BCM will help for sure
I believe your issue is in the ignition switch
SSKS
Can turn key to start and back to accessory position but key will go no further and of course will not come out. Keyless entry will not lock or unlock, envoy will not start, when turn key to run position service engine light comes on, have checked shifter boot as read in another that may not be allowing to go fully in park. Cannot move shifter to any position.
  • 75,988 POSTS
Are the brake lighst working?
Possibly a problem within the shift interlock control system such as the shiftlock solenoid
SSKS
i do not have any lights, beleive battery is almost gone, if i turn the key to the run position i get a service engine soon light but that is it.
  • 75,988 POSTS
Get the battery replaced or charge till its full and consider the above I've you
JGREAVES
When I turn the ignition key, nothing happens. Starter does not fire, dash lights flick but nothing. Had this same symptom a few months ago after a rain. Same damp conditions today.
HMAC300
  • 48,601 POSTS
check to see if your fuible links are ok. they may be losing contacts. they are small wires connected to larger wires near the starter. Also make sure your cables are clean negative and positive.
