Clearing the check engine light
MCAVINEE
  • 2003 HYUNDAI SANTA FE
I have a OBDI Meter and I need to know the location of the diagnostic connector on this model. The SUV runs fine but I noticed the engine light came on after I put in a can of Freon. Not sure if that triggered it or not. Would not think so, but that is all I have done
Sunday, May 19th, 2013 AT 5:12 AM
HMAC300
  • 48,601 POSTS
You need a obd2 not a 1 the connector shold be on bottom of dash under steering column or to the left of it.
Sunday, May 19th, 2013 AT 7:52 AM
MCAVINEE
  • 69 POSTS
Thank you. OBD2 is what I have. Sorry. I found it, was in a different place after I took the cover of the fuse box off, it was directly to the right of it. Cleared the check. It was a typical one that triggers it, OS2 I think it said.
Sunday, May 19th, 2013 AT 9:50 AM
