Clearance between piston and cylinder
2003 JEEP LIBERTY
76,435 MILES • 3.7L • V6 • 4WD • AUTOMATIC
IRAKLI IRAKLI
I have the vehicle listed above with an EKG engine. interested in the minimum and maximum clearance between the piston and the cylinders?
Aug 2, 2020 at 6:36 AM
Good afternoon,
The clearance is below. it is .014.
PISTON
Material .................... Aluminum Alloy
Diameter .................... 92.975mm (3.6605 in.)
Weight .................... 367.5 Grams (12.96 oz)
Clearance in Block .................... 0.014 ± 0.0003 in.
Ring Groove Diameter
No. 1 .................... 83.73 - 83.97 mm (3.296 - 3.269 in.)
No. 2 .................... 82.833 - 83.033 mm (3.2 61 - 3.310 in.)
No. 3 .................... 83.88 - 84.08 mm (3.302 - 3.310 in.)
Aug 2, 2020 at 6:53 AM
