Clapping sound?
139,777 MILES • 1.5L • AUTOMATIC
LILNIGHTMARE
OK, so I have adjusted the rear brake shoes probably about a half a dozen times now and after a driver too, I get the same result every time where when I press on the brake pedal, it sounds like a clapping sound is coming from the rear brake drum I’m not sure what I’m doing wrong with it but it’s getting very annoying and if you can give me any pointers or assistance it would be greatly appreciated.
Jun 11, 2026 at 9:26 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the rear brake assembly inspected before making further trial adjustments. The proposed spring problem needs confirmation along with correct assembly and adjustment using the vehicle's service information. If braking is abnormal, keep the vehicle out of service until checked. The owner's suspicion is a lead for inspection, not proof that a spring kit will resolve the noise.
Guidance references and applicability
Source discussion: question 1712855 https://2carpros.com/questions/clapping-sound--1712855 Supports the reported history and outcome only. Follow-up guidance is editorial synthesis; unverified specifications and diagnoses are not adopted.
Read the replies · Discussion summary and reported outcome
  • 55,710 POSTS
I would back off the adjustment slightly and give it another try, Also, recheck the brake springs and the condition of the shoes if they are worn or you have a broken spring that will be the issue. Can you please shoot a quick video with your phone so I can hear the noise? that way I can tell for sure what's going on. You can upload it here with your response.
Jun 12, 2026 at 10:05 AM
LILNIGHTMARE
Hello thank you for the reply after taking another look I believe that I need to change out the springs
Jun 13, 2026 at 4:51 PM
  • 55,710 POSTS
Yep, if the springs are broken or weak it will allow the brake shoes to ride against the drum and make that sound. Upload an image of the problem so I can help confirm if you can.
Jun 13, 2026 at 7:13 PM
Discussion summary
Clapping sound?
The owner reported a recurring clapping noise from a rear drum brake when applying the pedal, despite repeated shoe adjustments. After another inspection, the owner suspected the springs. No photograph, replacement result or confirmed diagnosis followed.
Reported outcome: No completed repair or noise-free follow-up was reported.
The noise was not recorded, and the condition of the shoes and hardware was not documented.
Read the original discussion
