Clank sound when put in gear
2005 KIA AMANTI
206,000 MILES • V6 • 2WD • AUTOMATIC
DONNA ESTES
  • 10 POSTS
Whenever I put it in gear there is a clank sound coming from the wheel on the passenger side.
Sep 8, 2020 at 6:06 AM
  • 110,240 POSTS
It could be a bad joint, axle bearing, motor or trans mount, and a few other things. Does it do it all the time? Does it do it in both reverse and drive?
If possible, can you record the sound and upload it for me to hear? That my help. Also, as mentioned above, it could be an joint. Check to see if the CV boots are torn or if they are in good condition.
I attached a pic below and highlighted the CV boots. Check their conditions. Also, here is a link that explains common symptoms of a bad CV axle joint. Take a look through it and see if anything mirrors what you experience.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
Sep 8, 2020 at 11:06 AM
DONNA ESTES
  • 10 POSTS
Yes, both in reverse and drive. I just replaced front axle, bushings and sway bar.
Sep 8, 2020 at 11:57 AM
DONNA ESTES
  • 10 POSTS
I'll get a video of the sound.
  • 110,240 POSTS
By any chance, have you checked the mounts/supports I mentioned? Also, have you checked engine mounts?
Sep 8, 2020 at 11:59 AM
DONNA ESTES
  • 10 POSTS
No I haven't. I will check it those. I did notice you can still hear a pop not a clank whenever you stopped and still in drive just waiting to go again.
Sep 8, 2020 at 11:58 PM
