Engine Clacking Noise On Acceleration?
101,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
ERICH PETERSON
  • 36 POSTS
I'm have this clacking/ticking noise around the engine on acceleration.
See video clip here: https://youtu.be/bVglT18w18Q?si=KLd8TjKhY7qYaj5V
Any ideas? It is louder in person.
Thanks
Apr 4, 2025 at 7:21 AM
  • 55,694 POSTS
Yep, I can hear a large exhaust leak, can you get closer to the noise to see where it is coming from, I see the EGR cross over tube which is a good place to start, also the one way check valve on the EGR tube must not exhaust back into the air induction system. Is the noise coming from under the van? Please check the exhaust manifolds for broken bolts as well. Please upload pictures or videos in your response of any problems so we can see what to help you with.
Apr 5, 2025 at 5:06 AM
