Clacking metal noise while driving
111,226 MILES
KIMBEERLY
When driving there it sounds of metal clacking like there was a loose metal hitting another metal on the front left side by the tire. This sounds a lot when driving and it even pops it sounds even more on uneven roads. Sometimes it sounds like popping when reversing. I already changed the shock absorber and the drive shaft, and it continues to make the same noise.
May 30, 2022 at 1:37 PM
  • 110,248 POSTS
When you replaced the strut/shock, were the strut mounts replaced as well? Also, have you checked to make sure there isn't a bad ball joint, stabilizer link, or control arm bushing?
Do me a favor. Take a look through this link and let me know if anything helps:
https://www.2carpros.com/articles/popping-noise
I will watch for your reply.
May 30, 2022 at 2:26 PM
