1993 Citroen ZX Cooling system capacity and draining proble
1993 CITROEN ZX
23STACEYC
Engine Cooling problem
1993 Citroen ZX Two Wheel Drive Manual 76000 miles
I want to drain and flush my zx reflex 1.4 but can't find the cooling system capacities anywhere. I don't want to drain it until I know I have enough to fill it! What is th capacity
Also I have heard that zx's can be a pain to replace coolant- with problems with airlocks. Where are the bleeding points on this model?
I really need to clean the system as it is discoloured, gunky and horrible (dispite the car still ploughing on) but don't want to unearth other problems in the process- any tips on making sure it goes smoothly and I don't blow the head gasket or anything?!
Oct 16, 2009 at 4:10 AM
DAVE H
  • 13,384 POSTS
your local autoparts sore will supply a repair manual with step by step instructions on the repair with diagrams and spec's
Mar 12, 2010 at 10:24 PM
