2003 Citroen Xsara juddering from steering wheel
2003 CITROEN XSARA
62,000 MILES • 4 CYL • FWD • MANUAL
POWELL1980
i had the car moted recently at a non citroen garage and it failed on a leaking powered steering pipe , they repaired the pipe now i have a juddering /vibrating coming from the wheel , not your normal turning a corner more nearer to full lock or when turning around , when i took it back to them they said it was probably pressure and i told them it wasnt doing it before they said its because the pipe was leaking so it wasnt performing properly
Apr 16, 2009 at 9:28 PM
DAVE H
  • 13,384 POSTS
have the steering rack check for wear/damage
Mar 12, 2010 at 10:15 PM
