2002 Citroen Xsara please help!
NIK_NAK
Steering problem
2002 Citroen Xsara Manual 150000 miles
Our Citroen Picasso is due in for its MOT and the sterring has progressivly become worse. At first it made a grinding noise on any right hand steering when going over 50 mph, but its progressed to grinding even during parking manoovers, on bothe left and right hand steering. Its an 02 reg and its done 150,000miles. The power steering fluid is not low either. It also seems that the steer has a slight left hand pull, if you drive in a straight line, the wheel turns to the left slightly too.
Any help would be much apprieciated.
Nov 2, 2009 at 8:20 PM
DAVE H
  • 13,383 POSTS
start by checking the wheel bearings are good !
Nov 7, 2009 at 11:31 PM
