2001 Citroen Xsara fan relay
96,000 MILES • 4 CYL • 2WD • MANUAL
BEN HANLEY
i do not know where my fan relay is. please help. my fan is not coming on and i'm overheating. fan does work if i short it. but there is no power reaching it. is it the relay and where can i locate it? help
Oct 1, 2009 at 9:07 PM
DAVE H
  • 13,383 POSTS
check the fuse ... the fan motor is controlled by the PCM/ECU (computer) which is sent temp signals from the coolant temperature sensor ...there is no relay !
Oct 21, 2009 at 1:31 PM
