two months ago i realised that when i turned at first position the key before start the engine the sound of the gas pump started geting louder and weer maybe like growling.First thing i did i replaced the fuel filter and then the gas pump as the noise is coming from its place.This growling hapens only at first start and when the engine hasn't run for half a day.Although everything seems to work fine the problem seems to deteriorate slowly by time and as always afraid about fuel matters i want to fix it.Thanks in advance for any input
Dec 10, 2009 at 9:51 PM
