1998 Citroen Xsara rear drums
MIKEJONES
Brakes problem
1998 Citroen Xsara 4 cyl Two Wheel Drive Manual
how do i remove the rear drums? do i have to remove the bearing to get the drum off? if so is it l/h thread or normal?
Aug 3, 2009 at 4:58 AM
DAVE H
  • 13,383 POSTS
on some models you have to remove the bearing on others you don't .. the bearing nut is a standard thread pattern .. it may just be helkd on tightly by the brake shoes !
Sep 19, 2009 at 11:18 PM
