1997 Citroen Xsara blowers not working
1997 CITROEN XSARA
155,000 MILES • 6 CYL • 2WD • MANUAL
HOWIEBHOY
Hi, my blowers have stopped working for a while now and I have eventually decided to try fix them b4 winter.
The problem started when the left control for the power output stopped working, it was stuck on full power, so i used the fuse to have them either on full or off. Then they ceased to work altogether. The interior fuse is fine, I thought it may have been the actual switch, so replaced the unit of three control and still nothing. What else could it be? are there any other fuses to check and if so, where? could it be the motor? wiring?
Sep 15, 2009 at 4:26 AM
DAVE H
  • 13,384 POSTS
replace the resistor located on the blower motor housing or the motor could be bad !!
Sep 19, 2009 at 11:12 PM
