1995 Citroen Xantia RADIATOR FAN
1995 CITROEN XANTIA
PAULGG1956
Engine Cooling problem
1995 Citroen Xantia
is it ok to put radiator fan on a switch inside car if this is the only way to get it to work bypassing switch on radiator
Apr 5, 2009 at 9:21 AM
DAVE H
  • 13,384 POSTS
you can wire a switch direct !! if you do wire it direct you have to make sure you turn it off when engine not running or it will flatten battery .. or check/replace the coolant temp sensor which sends the signals to the fan switch !
Sep 20, 2009 at 12:02 AM
