2001 Citroen Saxo engine sometimes rough
NEZ8NEZ
Engine Performance problem
2001 Citroen Saxo Front Wheel Drive Manual 84000 miles
hi my car seems to have a flat spot perticularly when driving at low speeds but if i press the accelerater down it seems to drive through it. its as if the car is going to stall but if you put your foot down it runs rough then clears up can you advise what this could be please.. thanks..
Nov 1, 2009 at 11:15 PM
DAVE H
  • 13,383 POSTS
check fuel pressure ..
Mar 12, 2010 at 9:50 PM
