2000 Citroen Saxo Starter Motor
2000 CITROEN SAXO
80,000 MILES • 4 CYL • FWD • MANUAL
STANBENDOWSKI
Hi guys, got a problem with the wife's car. As far as i am led to believe, the starter packed in last week (just getting a clicking noise). I got another one from a local breakers (he showed me it working on a live engine then took off for me) and when I fitted it on ours, as soon as i reconnect the batter terminals, it seems to be attempting to start itself (motor spinning). There is only 3 connections on it, 1 (on an 8mm bolt) which i presume is the ignition wire, top nut which seems to be for the earth wire as is only long enough to reach the top connection and that leaves the battery power cable which only has to be on the bottom connection. I cant find out if that is right but i assume so (someone else took the original starter off) so i am lost. Changed the 2 wires round and no performance from the starter at all but got me stumped. Ironicallly no local shops have a haynes manual in stock. can you help asap? the car running is a priority.
Many thanks,SB
Jul 27, 2009 at 9:26 PM
  • 31,937 POSTS
Hi there,
We do not have any info on this car, but it will be easy to workout the wiring, with 3 wires, one will be the main battery wire (12V constantly) this will be a heavy cable, solenoid wire will be smaller and have 12V only when key is on crank, and the earth can be check with a multi meter continuity to chassis earth will be 100% if the starter still spins when connected make sure that the solenoid wire is not touching the main feed cable. if the solenoid wire is active all the time there will be a fault in the wiring and probably the ignition switch, start here.
mark (mhpautos)
Jul 27, 2009 at 9:56 PM
