2000 Citroen Saxo ENGINE LIGHTS
2000 CITROEN SAXO
99,000 MILES • 4 CYL • AWD • MANUAL
IANK99
I HAVE JUST DRAINED THE RADIATOR AND USED RADWEL TO SEAL A TINY HOLE IN IT. SINCE IVE FILLED THE RADIATOR UP AGAIN THE FAN IS COMING ON, THE TEMPERATURE GAUGE LIGHT IS ON AND THE WATER ISNT STAYING LEVEL, BUT THERE IS NO LEAKS??!! WHAT HAS HAPPENED JUST DRAINING IT AND FILLING IT UP AGAIN? THANKS IAN
Jul 10, 2010 at 4:06 AM
DAVE H
  • 13,384 POSTS
you probably have air trapped in the system .. it needs bleeding off !
Jul 20, 2010 at 8:48 PM
