1997 Citroen Saxo oil leak
1997 CITROEN SAXO
15,000 MILES • 4 CYL • FWD • MANUAL
DEANSTER12
i have an oil leak coming from the oil feeders on my cylinder head,ive just replaced my head gasket.skimmed the head,ive had valve replacement .rocker cover and gasket replaced but its still leaking oil from the middle of the engine leaking down to the floor.is ther any way i could seal the oil feeders or whatever there called up
Apr 22, 2009 at 6:36 AM
DAVE H
  • 13,384 POSTS
Do NOT block the oil feeder tubes .. they are an important part of the engine ... remove the rocker cover gasket and replace with new and also use a good gasket sealer with the gasket !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_662.png
May 7, 2009 at 12:16 AM
