2006 Citroen Picasso windscreen washer motor not working
2006 CITROEN PICASSO
36,000 MILES • 4 CYL • 2WD • MANUAL
SHARPEY
windscreen washer motor not working i have checked the fuses and they are in working order any suggestions on the problem and how to repair please?
Feb 22, 2010 at 11:44 PM
DAVE H
  • 13,384 POSTS
check you have power to motor/pump .. check pump is working by adding direct power from battery .. blow out pipes with air .. check nozzles are not clogged
Mar 12, 2010 at 9:41 PM
