1999 Other Citroen Models No hot air coming from the heater
1999 CITROEN
CHINKY42
Heater problem
1999 Other Citroen Models All Wheel Drive Manual 1100 miles
Hi ive just bought a citreon berlingo van. When i put the heater on it only blowes slighty warm air. Do i need a new heater??
Jan 6, 2009 at 3:04 AM
DAVE H
  • 13,384 POSTS
check coolant level is correct ... check/replace the thermostat .. have the coolant system flushed to remove any blockages ..
Jan 10, 2009 at 3:01 AM
CHINKY42
[quote:9443273572="Dave H"]check coolant level is correct ... check/replace the thermostat .. have the coolant system flushed to remove any blockages ..[/quote:9443273572]
Thanks alot...i,ll try it xx
Jan 11, 2009 at 1:43 AM
