1994 Other Citroen Models clutch, gear box or both?
1994 CITROEN
ARNALDO
Transmission problem
1994 Other Citroen Models 4 cyl Two Wheel Drive Manual
got a citroen jumper.the gear stick works with cables .started to get hard and was dificult to select gears.
coupe days ago it got stucked in reverse and since then i cannot enter other gear. also start to hear a noise coming from, i think , the clutch bearing.
but when i press the cluch pedal the engine runs free and the noise slows down a bit. the question is: is the clutch gone, is a problem in the gear box , both or else?
Aug 16, 2009 at 12:05 AM
DAVE H
  • 13,384 POSTS
check the linkage is working correctly
Aug 30, 2009 at 1:36 AM
