2003 Citroen C5 change fuel filter
98,000 MILES • 4 CYL • FWD • MANUAL
SALLY1688
C5 HPI Estate Car. fuel filter is located under rear seat, wanting to know how to change this. Is it a sealed unit and buy replacement unit or does filter need to be removed from a unit for replacement. Also which ever it is how to remove it. Thanks
Aug 16, 2009 at 8:58 PM
DAVE H
  • 13,383 POSTS
the filter is part of the pump module and you would need to replace the pump to replace the filter !!
Aug 30, 2009 at 1:12 AM
