2002 Citroen C5 turbo testing
CARBONUNIT1
Computer problem
2002 Citroen C5 4 cyl Front Wheel Drive Manual 143.00 miles
hi,anyone know how to check out a turbo on one of these without using citroen diagnostic machine at 60 quid a go,,can you put a gauge into system and what should it read,,thanks 4 reply from dave sugesting blocked cat,maybe,i have topped it up with eloi fluid and given it a good ron,,ie140 miles per day at 70 plus mph,,lights come and go,stop,light anti pollution caption esp light eng man light,somtimes goes into crawll mode,lacks powerr on hills,cit diagnosis is turbo,but it sucks and blows,no smoke ,turbo spins freely,no bearing wear,no disernable leaks in induction system from intercooer,
Mar 16, 2010 at 2:12 AM
DAVE H
  • 13,383 POSTS
The cars PCM (computer) must be storing codes ? could you supply the fault codes ?
Mar 17, 2010 at 1:35 AM
