2002 Citroen C5 power steering
XMAZZX
Steering problem
2002 Citroen C5 6 cyl Two Wheel Drive Manual 67.000 miles
I need to top up my power steering fluid which is the one I need to use? and can I top it up myself as it says on container inside engine compartment to top it up by taking it to a citroen garage also where is the pollen filter on my c5
Oct 16, 2008 at 7:07 AM
DAVE H
  • 13,383 POSTS
Pollen filter is located under the plastic panel under the grill at the bottom of the windscreen ... you need a good "power steering fluid" to top up container !
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_117.png
Mar 9, 2009 at 11:13 AM
