2005 Citroen C4 Oil & filter replacement
2005 CITROEN C4
25,000 MILES • 4 CYL • FWD • MANUAL
ANDREW CAUSIER
I would like to know how to remove & refit the oil filter on my 1600cc C4 the filter is a type I have never used before it it is not the old type metal canister screw on type. The filter housing appears to be made of plastic and the new filter I have is a new paper type filter that fits inside the plastic housing. the housing doesn't appear to have any clips holding it on and I am unsure how to remove it so I can change it.
Many thanks
Andrew
Apr 16, 2008 at 5:19 AM
DAVE H
  • 13,384 POSTS
your local library should be able to supply a manual for the vehicle .. it is a simple repair there should be a bolt straight down the middle of the filter housing !!
Mar 4, 2009 at 10:03 AM
PAM PERRY
Hi
Use a 27ml spanner on the hexagon.
Remove paper catridge from inside plastic housing
Fit new cartridge and new O ring
Sep 4, 2009 at 12:55 PM
