2005 Citroen C3 How to fix without to much cost
2005 CITROEN C3
59,631 MILES • 4 CYL • 2WD • AUTOMATIC
STEVAN STORY
HI the problem i'am having i'am told is gearbox temperature sensor fault permanent, gearbox level low intermittent the car is a c3 sensodrive how easily to repair is this expensive .
May 7, 2010 at 11:16 PM
DAVE H
  • 13,384 POSTS
you really need a transmission repair centre to look at the vehicle .. the low fluid level means it must be leaking and this could be causing the overheating
May 30, 2010 at 12:38 AM
