2004 Citroen C3 sterring
GAVINJAMES
Steering problem
2004 Citroen C3 4 cyl Front Wheel Drive Manual
steering wheel locked and keys not turning to unlock it or start engine
Apr 23, 2009 at 10:16 PM
DAVE H
  • 13,383 POSTS
Try spraying WD40 down the lock barrell and turning steering wheel from side to side while trying to turn the key .. if this does not work it will have to be drilled out i'm afraid .. if it does work have the ignition lock replaced ASAP
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_664.png
May 7, 2009 at 12:25 AM
