2004 Citroen C3 Fuel Injection Failure
2004 CITROEN C3
42,000 MILES • 4 CYL • 2WD • MANUAL
WAYNE.PEACH
Hello there my car has suddenly out of the blue developed a fuel injection failure. when the car has been stationary for quite a while this problem goes away, only to return again after about 15 mins of driving.
The symptoms are the engine sounding sluggish, shuddering, engine cutting out whilst driving and also cutting out in low revs/low gear.
I have been told that if I use redex or such like then this should clear it?
If there is anything I can do without the need to go to a garage I would greatly appreciate your advice as I have been ripped off big time in the past.
Also I had my car put through an mot just 3 weeks ago, surly this problem should have been found then??
Feb 8, 2008 at 3:05 AM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
firstly how do you know it's a fuel injector ? secondly engine performance is not tested on MOT unless it is causing Emmission failure .. have the vehicles PCM (computer) read for fault codes .. i would be looking more at a coil failure with the symptoms your describing .. if it is actually an injector this is an easy repair
Mar 1, 2009 at 8:33 PM
