The symptoms are the engine sounding sluggish, shuddering, engine cutting out whilst driving and also cutting out in low revs/low gear.
I have been told that if I use redex or such like then this should clear it?
If there is anything I can do without the need to go to a garage I would greatly appreciate your advice as I have been ripped off big time in the past.
Also I had my car put through an mot just 3 weeks ago, surly this problem should have been found then?
Friday, February 8th, 2008 AT 3:05 AM
