2007 Citroen C2 Windscreen Washers
28,000 MILES • 4 CYL • FWD • MANUAL
RUSS14
The windscreen washer are not working, there is plenty of water in the bottle and its not frozen. Also i cant here the pump working, ive tried the obvious things and there are no blockages that i can see??
Any suggestions as to what it could be?
Jan 18, 2010 at 12:22 PM
DAVE H
  • 13,383 POSTS
check fuse ! .. blow through pipes with compressed air .. check for clogged nozzles
Jan 23, 2010 at 8:22 PM
