2006 Citroen C2 c2 elec windows
MARK1888
Electrical problem
2006 Citroen C2 Front Wheel Drive Manual 35k miles
My driverside window has stopped working after another fuse was found to be blown and replaced . Where is the fuse for it , or is it not that easy?
Apr 19, 2010 at 10:05 AM
DAVE H
  • 13,383 POSTS
all windows would not work if fuse was blown .. check the switch/motor/wiring
Apr 23, 2010 at 9:06 PM
MARK1888
Found the problem , there is a fuse board above the main interior fuse board with only one 5a fuse . i replaced this and hey presto , it worked . Could this be for the anti pinch mechanisim ?
Apr 25, 2010 at 2:09 AM
