2000 Citroen C2 Rattle or vibration noises
THREADONASPOOL
Noises problem
2000 Citroen C2 Engine Size unknown Two Wheel Drive Manual 86000 miles
Hi Guys,
Peuteot 206 diesel!
Theres a terrible vibration coming from somewhere underneath the gear stick area. I can really hear it in first and second gear. The higher the revs the louder it gets. Usually its only noticeable over 2000 RPM in 1st and 2nd. I had a mechanic check it but he wasn't able to find the problem. Any ideas???
Hope you can help!
Gerry
Feb 28, 2008 at 8:07 AM
DAVE H
  • 13,383 POSTS
check the heat shield on the exhaust is not loose or broken
Mar 1, 2009 at 2:11 AM
