1998 Citroen C1 engine
96,000 MILES • 6 CYL • FWD • MANUAL
FESWICK33
my engine will not shut off when i remove the ignition key
Jul 12, 2008 at 2:18 AM
DAVE H
  • 13,383 POSTS
i'me assuming the key is working correctly ? at the rear of the ignition barrel where the wires connect to a plastic cap undo the clips to remove this cap from barrel .. you will find the centre of this cap is worn .. you need to replace this cap .. inside this cap is what turns on and off the ignition.. you need to solder a new cap to the existing wires in the correct order ?
Nov 6, 2008 at 11:02 AM
