1997 Citroen C1 Self Revving Engine
85,000 MILES • 6 CYL • FWD • MANUAL
JOHNNYP60
Hi sorry the Car is not a C1 it is in fact a manual 1litre Cireon AX, the car starts fine but you will be driving along and it will start to Rev itself to red-line, I have to drive it with my foot on the break changing gear so as not to blow the engine, if i have to stop i have to cut the engine off then try and start it again 9 times out of 10 after it has rev'd itself it wont start, any ideas?
May 12, 2008 at 8:35 PM
DAVE H
  • 13,383 POSTS
The carburettor on the ax is controlled by the ECU/ECM so i suspect you are getting a wrong signal being transmitted to the carb .. try reading the ECM for fault codes
Nov 6, 2008 at 10:47 AM
