1995 Citroen C1 My Citroen Ax cooling Fan Problem.
85,000 MILES • 4 CYL • FWD • MANUAL
TAMER989
I have a 1995 citroen ax with a cooling fan that never stops.
This problem occured b4 and it was fixed in the garage but costed alot, the problem was simple as a cut in a wire or plug or something.
Thermostates, fuses and all related computer things are all ok but the problem is simple and i just cant figure how and where is this problem so please help me.
Dec 24, 2007 at 7:58 AM
MJAINAL
Please check the relays. There are 2 relays related to the fan. One is for direct fan (activated by thermostatic switch) and the other is for air-conditioning system. You can find both relays around the battery area (Most likely near the brake master pump).
You can check for burn or loose connections. Hope this helps.
Jun 4, 2008 at 6:31 PM
