2004 Citroen Berlingo Car not starting
128,000 MILES • 4 CYL • FWD • MANUAL
NICKY.VC
I have the Berlingo 2 and removed the positive from the batery to jump a other car. Now my car will not start, the engine turns but no starting. The onboard display reads ECU MOD. Have disconected all the cables and checked the votlage of the bty. After replacing bty still the same. Can you assist
May 25, 2010 at 1:32 AM
DAVE H
  • 13,383 POSTS
have the car plugged into a diagnostic computer to locate the cause of the fault .. check all fuses are good
Jun 26, 2010 at 9:04 PM
